New Display 0.49 inch
A project log for Arduino Glasses a HMD for Multimeter
Building an HMD with no special parts, to make work easier and safer
alain-mauerAlain Mauer 10/18/2016 at 19:565 Comments
The new displays just arrived. Will build a smaller version.
I think I will start a new project for this.
JVS wrote 04/24/2018 at 23:48 point
Link to these displays?
Mulyadi Santoso wrote 11/16/2017 at 01:37 point
Hi alain,  the picture after going through the reflected mirror, it will be reversed (right as left). Did you make the initial drawing reversed , to adjust this? Thank's
aerbey wrote 10/21/2016 at 09:18 point
Hello Alain, i liked your project. Im also interested in this HMD field. I was looking for a starting point and i found your tutorial helpful.  I was looking for possible displays recently. I have thought to work with this 0.5 inch full color display:  http://www.alibaba.com/product-detail/Full-Color-OLED-microdisplay_673088898.html?spm=a2700.7724838.0.0.OrOwJA
But i realised its hard to drive. There also exist LCOS displays price around 80$ they are also below 0.5inch and full color. But they all need some expertise in display driving. Right now i will start working with your first 0.66 inch display to have an idea. I will be following your updates also.
Alain Mauer wrote 10/21/2016 at 09:45 point
Great. As you can see I am trying now this 0.49 Displays to reduce the size of the data glasses. I think I will do a PCB for this one. But the microdisplays you found seems to be a good starting point for a more evaluated data glasses.. In fact, I am not done with this project. It works really good, but I have a few changes in mind. I will move in a new house end of the month, so that I think the project will be on hold until January
I seen LCOS used with beam splitters, could work
Also it might be cheaper to buy a used pair of videoglasses to get the parts.
