Spindle support
A project log for DIY CNC MACHINE
Wood structure, arduino controled, cheap and easy to build.
jvsalatinojvsalatino 06/16/2016 at 15:070 Comments
The spindle support depend on of the type of spindle you use. If the spindle it's bigger maybe you need to put a bigger motor in the Z axis
