Colors of Photons
This painting change in each moment
Acrylic and pigment Painting on acrylic glass - with LED light with intelligent functions A day we start using Eva`s acrylic glass which was many years ago in the attic,, until now, and the inspiration came.. Eva make beautiful abstract painting than we try to add Neopixels LED, Microcontroller, some code..The already fabulous painting with the continuously changing rainbow colors become magic miracle. We watched than we was so relaxed just a deep calmness, peace, with Love. Eva Konya using her amazing technique which came from her talent using the colors to make the painting so amazingly beautiful visual impact. “I am excited of " Multi Media" projects and build, programming intelligent lighting objects which continuously changing and can sensing their environments and our presence” "It reminds me that existence is none other than the constantly changing present." Janos Magyar
Stage 2
The sensing functions I am still working, I must figure out how and where to put the sensor inside the frame,ultrasonic etc. and also i need programming, which i must figure out,how can i do :)
I already make wifi version as well with Particle Photon and with Android app to control the NeoPxels over internet. That let you change all the LED`s colors individually without programming. IFTTT also working with this Spark Pixels app and also with the Particle photon it self see more on https://community.particle.io/
You can "paint" mix the colors it will be fixed non moving, you can adjust the brightness on any moving mode the speed to.
Acrylic and pigment Painting on acrylic glass,of course need some practicing and playing with the colors, but if you like to painting.. well I am lucky because Eva teach me.
The photo foam board need,because protecting the painting about scratch,and also reflecting the light.
  • 1 × Particle Photon
  • 1 × Adafruit Pro Trinket - 5V 16MHz
  • 1 × NeoPixel Digital RGB LED Strip 144 LED
  • 1 × acrylic glass/ 1 cm thick/ / I use this two size 100 x 60 cm or 30 x 30
  • 1 × Adafruit Rugged Metal On/Off Switch with Green LED Ring
View all 12 components
  • 1
    Step 1
    Testing with Lilypad,Particle Photon, Arduino uno . It was so cool saw the first time ,like a living entity.
    With Particle Photon
  • 2
    Step 2
  • 3
    Step 3
    This with Adafruit Pro Trinket 5 volt
View all 4 instructions
