First Charge / Discharge Cycle
A project log for A 110 kWh Powerbucket
The lead-acid batteries of my off-grid solar system are dead. I will replace them by a 18650 batteries stack housed in a big wooden box.
michel-kuenemannMichel Kuenemann 11/30/2016 at 05:362 Comments
Thanks to the bright and sunny day, the batteries could perform their first charge / discharge cycle yesterday:
A few comments:
The battery behavior is really great. Its voltage reflects well its state of charge.
The system switches currently automatically back to grid when the battery has lost 4 kWh. This figure could be increased to 6 or 7 kWh to use more of the battery capacity. (Nominal capacity is 11 KWh).
Michel Kuenemann wrote 11/30/2016 at 20:21 point
Hi Gilles,
Thanks a lot .
CU
Gilles KREBS wrote 11/30/2016 at 11:13 point
Good job Michel!!
