Manufacturing 15 modules
A project log for A 110 kWh Powerbucket
The lead-acid batteries of my off-grid solar system are dead. I will replace them by a 18650 batteries stack housed in a big wooden box.
michel-kuenemannMichel Kuenemann 11/26/2016 at 16:510 Comments
The modules are ready for integration:
The modules weigh less than 3.7 Kg. Total weight will be of 15 * 3.7 = 56 Kg approx.
Spot welding the positive terminals of the Hybrid module:
The fuses are soldered on the copper bars thanks to the Jig.
The fuses (Negative terminal) are being welded:
