IoT shield for ESP8266
This project is an IoT sensor shield for the ESP8266 and it's Arduino compatible
This project consists of an Arduino Shield compatible for the WeMos D1 (retired) with the following sensors and actuators:
- Relay for up to 10A
- Push button
- LDR (light sensor)
- DHT11 or DHT22 (removable socket)
- RGB LED (high brigthness)
- I2C connector with pullups
This shield was created to be a simple startup for beginners and also to be used during IoT ESP8266 trainings. Using this shield, we can create a lot of projects in minutes without any soldering or wireups.
The PCBs were made by PCBWay.com and I'm very satisfied about the quality and production time.
esp-sensor-shield.sch
Eagle Schematics file
x-eagle-schematic - 362.16 kB - 12/27/2017 at 21:42
Download
esp-sensor-shield.brd
Eagle PCB file
x-eagle-board - 118.42 kB - 12/27/2017 at 21:42
Download
ESP_SENSOR_SHIELD.zip
GERBER Files
Zip Archive - 49.50 kB - 12/27/2017 at 21:41
Download
Adobe Portable Document Format - 56.27 kB - 08/03/2016 at 01:07
Preview
Download
iot-shield-BOM.ods
IoT Shield BOM
application/vnd.oasis.opendocument.spreadsheet - 12.11 kB - 07/22/2016 at 13:10
Download
  • 4 × 2N2222 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × LDR Resistor Networks / Thick Film Networks
  • 1 × Relay Power Supplies / Uninterruptible Power Supplies (UPS)
  • 1 × RGB LED SMD 5050
  • 1 × 1N4148 Discrete Semiconductors / Diodes and Rectifiers
View all 10 components
View all 6 project logs
tomdwane22 wrote 04/09/2019 at 04:38 point
How can a hacker exploit the esp8266 board to enter a company network if there is a temperature sensor iot device with the esp8266 in that specific network
John Kemker wrote 11/16/2017 at 16:53 point
Is there a source for the PCB file, so others can get them made?  Or, is there a way to purchase them from you?
mauricio wrote 06/20/2016 at 03:51 point
Good work
