Chamber
A project log for Zymeter
A device to monitor the progress of fermentation (pH, specific gravity, alcohol, temperature)
anfractuosityanfractuosity 06/15/2014 at 15:400 Comments
The chamber will have two pipe connectors, in order to pump liquid through it.
At the top of the chamber will be a piece of glass, which will be used in order to create a well defined reflection of the ultrasound pulses.
In order to pump liquid through the chamber, I will likely make use of a peristaltic pump, as we don't need a high flow rate and also they help keep things sanitary.
