twi-housing-panels-20mm.stl
20mm top and bottom housing panels for 3D-printing. I printed with 0.2mm layers and 90% infill set to cubic.
Standard Tesselated Geometry - 727.72 kB - 12/12/2019 at 01:45
Download
twi-housing-panels-10mm.stl
Thinner 10mm top and bottom housing panels for 3D-printing. I printed with 0.2mm layers and 90% infill set to cubic.
Standard Tesselated Geometry - 728.70 kB - 12/12/2019 at 01:45
Download
T.WI.nufilter.hex
Version with DSP lo-pass filter for breath signal instead of simple smoothing, for faster response.
hex - 84.64 kB - 05/15/2018 at 06:00
Download
twi-side2.stl
Side pieces for 3D-printing. For use with 6mm M2 standoffs and laser cut or carefully hand cut and drilled perspex sheets from template.
Standard Tesselated Geometry - 7.50 kB - 11/22/2017 at 17:10
Download
twi-side1.stl
Standard Tesselated Geometry - 7.11 kB - 11/22/2017 at 17:10
Download
T.WI.hex
New version firmware for upload using Teensy Loader.
hex - 54.88 kB - 10/31/2017 at 15:47
Download
T.WI.ino
Source code for new version T.WI
ino - 24.41 kB - 10/31/2017 at 15:26
Download
twi-userguide.pdf
User guide for the new version T.WI
Adobe Portable Document Format - 409.35 kB - 10/31/2017 at 15:25
Preview
Download
twi-cut.pdf
Template for cutting/drilling the sheets.
Adobe Portable Document Format - 34.75 kB - 10/25/2017 at 17:39
Preview
Download
How the T.WI can be put together with 6 mm nylon spacers/standoffs and M2 nylon screws.
Portable Network Graphics (PNG) - 612.53 kB - 10/21/2017 at 19:25
Preview
Download
Schematic for T.WI with PSP1000 joystick. Version for use with new firmware version.
Portable Network Graphics (PNG) - 45.96 kB - 10/21/2017 at 17:34
Preview
Download
T.WI-settings.pdf
Settings chart for new version.
Adobe Portable Document Format - 50.29 kB - 10/21/2017 at 13:58
Preview
Download
TeensieWI.ino
Source code for the original version without joystick. Part of my bigger MiniWI project on Github. Licences and more stuff is found over there.
ino - 7.86 kB - 06/20/2016 at 19:32
Download
Original version. It is really this simple. I promise.
Portable Network Graphics (PNG) - 21.06 kB - 06/20/2016 at 19:31
Preview
Download
Fingering chart for the TeensieWI.
Portable Network Graphics (PNG) - 214.33 kB - 06/20/2016 at 19:30
Preview
Download
