DAV5 V2 Spectrometer
The ZEN of simplicity
Making the Complex...Seem Simple
The DAV5 V2 Spectrometer is the only project build here on Hackaday in its category, with full performance and specifications documentation thus far. The main goal for this project has 4 points:
1) To build a rugged and reliable low cost spectrometer with readily available parts
2) A spectrometer capable of producing consistent and professional quality results in the field, home or Lab
3) A device with upgradeable capabilities
4) A device with minimal setup and prep time/ i.e., just plug it in and run!
CMOS Camera Module: JDEPC-OV05
cmos camera focal length is now calibrated at 152.39mm (camera focal eye to forward face of cuvette holder.)
Measurements between the slit to cmos camera eye are not as important as precise alignment of camera to DVD grating and DVD grating to slit entrance, so with this in mind, the camera is now at 40 deg relative to slit entrance and DVD grating is at same (40 deg) relative to cmos camera eye.
The ruling density of the DVD grating is 8.5 GB 0.36mm groove spacing, which equates to 2770 lines per mm, wavelength of 360nm. The slit width is now 0.16mm and a spectral bandwidth of 1.19nm, using the new Gillette razor blade design I made. Project box dimensions are: 190mm X 109mm X 55mm.
Slit width dimensions are: 25mm in length, Cmos camera from slit: 88mm Camera angle: 40 degrees DVD grating angle: 40 degrees. Entrance coupler for slit and cuvette holder: 44mm in Diameter.
Wavelength range = 353nm – 693nm (reliably)
I replaced the old JDEPC-ov04 webcam with the more recent modification from the same company, with the one you can purchase now from Plab store. The JDEPC-ov05 and removed its IR filter. I will be posting it's specifications here also, I preformed the same theoretical calculation for resolution below, with the new values of 0.16mm slit width and a new DVD grating of 2770 lines, using 532nm laser, as my resolution wavelength:
1 X 0.16mm X 2770lines = 443.2
R = 531.2/443.2 = 1.19
Resolution= 1.19
So I have a bandwidth now of 1.19 (nm), which I feel comfortable with. I used my portable laser as my calibration vehicle (which is very stable, so I trust it's FWHM value.)
forward facing view of the DH 4.0 v4 spectrometer
Portable Network Graphics (PNG) - 615.52 kB - 09/04/2016 at 11:06
Preview Download
Page 5 spec sheet for CMOS camera module for the DH 4.0 v4 Spectrometer
Portable Network Graphics (PNG) - 40.74 kB - 08/28/2016 at 11:21
Preview Download
Page 4 spec sheet for CMOS camera module for the DH 4.0 v4 Spectrometer
Portable Network Graphics (PNG) - 88.97 kB - 08/28/2016 at 11:20
Preview Download
Page 3 spec sheet for CMOS camera module for the DH 4.0 v4 Spectrometer
Portable Network Graphics (PNG) - 87.28 kB - 08/28/2016 at 11:20
Preview Download
Page 2 spec sheet for CMOS camera module for the DH 4.0 v4 Spectrometer
Portable Network Graphics (PNG) - 49.83 kB - 08/28/2016 at 11:19
Preview Download
View all 12 files
  • 1 × JDEPC-OV05 Cmos camera ( cost 30.00 Plab store ) 1080P 720P UXVGA SXVGA VGA 1920x1080 1280 x 720 1600x1200 800x600 640x480 15fps 30fps 15 fps 30 fps 30 fps
  • 1 × Gillette Metal Razor Blades (Utility Knife standard size) 1 pk (I pair to make entrance slit)
  • 1 × Wood Block cut at 45 degree angle Used to mount CMOS camera with Gorilla 2 sided tape
  • 1 × Project Box ( black ) cost 7.95 Dimentions 190mm X 109mm X 55mm
  • 1 × Non-Compressible Black Foam Yoga Blocks ( high density ) set of 2 8.99
View all 10 components
View all 71 project logs
View all 21 instructions
