Quantum Yield of Rhodamine B in Ethanol (Gain Corrected Spectra)
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
david-h-haffner-srDavid H Haffner Sr 07/12/2016 at 21:160 Comments
Well, this is very promising, with my homemade spectrometer Plab v2.5, I was able to actually (and accurately,) measure the relative quantum yield of Rhodamine B in Ethanol. My Reference stock solution of Rhodamine B had a quantum yield of 68.5 and two other samples hit it right on the mark with 70.1 and 70.8 percent!
All for under a hundred dollars :)-
Here are a couple of plots to show what I'm taking about, the rest of my research can be found here: http://publiclab.org/notes/dhaffnersr/07-12-2016/quantum-yield-of-rhodamine-b-in-ethanol-gain-corrected-spectra
This next one is the quantum yields:
