Special Scan - Sweet Wyoming Crude Oil 2D EEM Analysis of 0.11mm Slit Width
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
david-h-haffner-srDavid H Haffner Sr 08/22/2016 at 12:360 Comments
These are 4 EEM graphic plots showing the before and after effects of removal of Rayleigh/Raman Scattering of the spectral captured data.
Here is the first 2 plots illustrating the removal of the 1st and 2nd order Rayleigh peaks, and the removal of Raman scattering.http://publiclab.org/notes/dhaffnersr/08-22-2016/special-scan-sweet-wyoming-crude-oil-2d-eem-analysis-of-0-11mm-slit-width
These next 2 plots show the before and after effects
Here is the Emission plot of the sample of crude oil using my UV laser pointer as the excitation source
Some conclusions, I am satisfied with this body of evidence from this latest research and the past two research notes I have posted on the difference between using Plab's acetate film strips as slits and using a much more stable and reliable open-air design such as the Gillette Metal razor blade 0.11mm slit I constructed.
