2 New Pics of the DH4.0 v4 Spectrometer
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
david-h-haffner-srDavid H Haffner Sr 09/03/2016 at 19:580 Comments
This is what my spectrometer looks like at the present moment...
The cuvette holder is designed to accommodate both forward facing geometry and perpendicular geometry as well ( 90 degree angle.)
This is the second view with the forward face cover on. ( it would be covered when doing fluorescence spectra, then you would remove the plug on the side for your 90 degree angle.)
Do the opposite for absorption spectra, remove the front cover and place the plug back in the side.
