Microscopic View of Plab Acetate slit and My Gillette razor Blade Open Air Slit
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
david-h-haffner-srDavid H Haffner Sr 09/06/2016 at 17:072 Comments
Using my Premiere professional binocular microscope (model - 3000,) and a new camera I got for it; an AmScope MD-500 5 megapixel HD cmos camera, I was finally able to image both slits at 100 X magnification with great clarity, here is what they look like;
I would rather use my open-air slit design...
David H Haffner Sr wrote 09/06/2016 at 19:06 point
I think there is with the acetate film slits, I compared 2 laser lines (532nm) thru a quartz cuvette filled with Ethanol and the EEM plots showed that the peak signal for the acetate slit was "flat," while the open-air design slit was nice and sharp. http://publiclab.org/notes/dhaffnersr/08-20-2016/eem-2d-spectrums-showing-evidence-of-attenuation-from-imperfections-in-acetate-film-strips
Ted Yapo wrote 09/06/2016 at 17:47 point
Hi David - I certainly don't like the bubbles in the acetate; your razor slit is much nicer!  I was wondering, though, if there is a Fourier windowing effect that happens with the slits where a gradual cutoff at the edge can reduce diffraction artifacts - like windowing an FFT to prevent edge effects?
