New testing on a 0.05mm Gillette razor Blade Utility Knife Open-Air Slit (based on my previous design.)
I wanted to see just how much more resolution I could squeeze out of this spectrometer, so I remove the 0.09mm Gillette razor blade slit and redid the design with a pair of Gillette utility knife razor blades. This took me about two hours to get it perfect but I got it right, now I have a 0.05mm open-air slit width, pretty incredible I would say, I used the same testing method as I did in a previous post on the 0.09mm open-air slit.
Now I have a spectral bandwidth of 0.68nm, and here is my proof;
An EEM (emission excitation matrix,) allows for a kind of 2 dimensional view that lets one examine in detail, an emission (X-axis,) and an excitation (Y-axis,) of your data.
The next plot is Fig.1, which is the peak for the 532nm green laser;
Fig.2 is zoomed in 1X, to show full laser line (532nm);
Fig.3 are both lasers together, wavelength range is 400 - 600nm;Fig.4 is the 405nm UV laser pointer peak;reference
