Continuation of a previous project
A project log for low-field MRI Continued
An attempt at a prepolarized Earth's-field compressive magnetic resonance imager
peter jansenpeter jansen 06/22/2016 at 05:130 Comments
This is a continuation of a previous project that was placed on the back-burner when I encountered a few roadblocks.
The previous build logs cover the concept, a MATLAB simulator, and measuring magnetic fields in a volume: https://hackaday.io/project/5030-low-field-mri
