BEWARE of Quartus JTAG Programmer on Linux
A project log for CLONE BUINO DUAL
兩個控制台模擬器 Two console simulators
martin-cejpMartin Cejp 04/29/2018 at 08:094 Comments
If you plug in your eBay "Altera USB Blaster" and try to talk to you device, chances are you get an error such as this:
/opt/intelFPGA_lite/17.1/quartus/bin> ./jtagconfig -d
1) USB-Blaster [2-2]
  Unable to read device chain - JTAG chain broken
  Captured DR after reset = ()
  Captured IR after reset = ()
  Captured Bypass after reset = ()
  Captured Bypass chain = ()
  JTAG clock speed 6 MHz
This would usually indicate that something is wrong with your board, the power, the FPGA, or perhaps the programming cable. Don't despair!
There is a known issue which is still present in the latest versions of Quartus. It has to do with a library called libudev. It is easy to find solutions for various distros, but I haven't seen one specifically for Fedora (27). In my case, what worked was:
ln -s /lib64/libudev.so.1 /lib64/libudev.so.0
Now the board is detected and can be programmed.
What have I learned? If you can't 1-800-JTAG to your board, check with a known-good board to quickly find issues on the PC side.
korane7208 wrote 06/18/2021 at 17:21 point
thanks for the solution! i was going nuts as well!
in my case of ubuntu 21.04, libudev.so.1 was in /usr/lib/x86_64-linux-gnu/ instead
Alain Lou wrote 02/07/2021 at 02:43 point
@dist.sys.engineer
I'm not sure I totally understood your error, but here are some things you could try:
1. Configure udev:
https://www.youtube.com/watch?v=hEi8nqpQv60
(you may need to reboot after configuring udev)
2. Plugging in stuff in the "right" order (this is what solved my problem on RHEL 8)
community.intel.com/t5/Intel-Quartus-Prime-Software/USB-Blaster-Unable-to-read-device-chain-JTAG-chain-broken/m-p/180907#M45366
(see the comment starting with "I find the issue: The USB-blaster must first be powered from the board and then connected to the PC.")
dist.sys.engineer wrote 01/27/2021 at 22:27 point
Good Afternoon and Thank You for helping resolve this issue.
I have tried everything, scouring the internet for days to use my Altera USB Blaster on Ubuntu 20.  It works with the drivers on my windows machine but I do all of my development on my Ubuntu laptop.  I have set the permissions, but I get an error message from dmesg|tail when I first plug in my device to my PC.  Also, installed Quartus II, and jtagd --debug shows a message can't claim interface.  jtagconfig says that the chain is already in use.  I took screenshots and have them on my developer blog here
https://codeandbuildit.com/2021/01/27/fpga-buck-boost-01-27-2021-programming-fpga/
Any help is greatly appreciated.  Kind Regards,
tommy-hackaday.io wrote 06/15/2019 at 06:55 point
Thanks that worked for me!  I was going nuts.
