Stop that snail!
A project log for Zombie Snails: Mindless Methodical Movement
A study on central pattern generators (CPGs) that control eating behaviors in pond snails.
nancy-sloanNancy Sloan 06/27/2016 at 18:540 Comments
More clearly explained, inject the snail before it hides behind its trap door anyway. For the past 2 weeks, I've had considerable trouble getting the needle into the snail to inject it with the anesthesia solution before the snail locked itself away in its trap door. It's actually a very fast and strong protection mechanism, considering it's a snail. I ordered needles off of Amazon that were wonderfully priced, however were not sharp enough to do the job. Even when trying to shave it down, it just didn't work. Your local CVS will have a needle for insulin injection so use that if you must. It has a beveled tip to the needle and a very nice 3 mL syringe for injection. Make sure you have these items before starting!!!
