Organizing and Such
A project log for Monoprice Select Mini Upgrades
I've created this project to make the Monoprice Select Mini 3D a descent and affordable solution. For the $200 Price Range.
adam-mAdam M 06/24/2016 at 20:140 Comments
I didn't like using the logs for work progress. I did wan't the most important stuff at the bottom, so I moved everything to the step-by-step section. I'll just use the log for general comments going forward.
