• Update #2
    Endbots07/18/2016 at 18:15 0 comments
    I completed the controller. It works quite well. The aluminum plate has quite a bit of thermal mass so it retains heat for a long time. If there is interist I might post a video of me using this to do some smt soldering. It sure beats using a regular hot plate.
  • Update #1
    Endbots06/23/2016 at 23:06 0 comments
    I ordered the last parts I need from Mcmaster Carr should have everything in a day or two.
