Update #2
07/18/2016 at 18:15 • 0 commentsI completed the controller. It works quite well. The aluminum plate has quite a bit of thermal mass so it retains heat for a long time. If there is interist I might post a video of me using this to do some smt soldering. It sure beats using a regular hot plate.
Update #1
06/23/2016 at 23:06 • 0 commentsI ordered the last parts I need from Mcmaster Carr should have everything in a day or two.
