Reactron Overdrive
A small but critical number of minimally complex machines interact with each other, providing machine augmentation of human activity.
The system is non-invasive and collects biometric and other data to coordinate connected devices with one's activity. A standardized control board turns non-connected devices into connected ones. The combination of a small number of simple devices can produce a large number of useful results, without the hassle and failure rate of larger, more complex and expensive single-purpose systems.
Most importantly, it saves time - the one thing in life that can never be replaced. The system manages asynchronous tasks and delivers the results - information or physical - just at the moment they are needed. It enhances personal workflow, instead of bottlenecking it with an attention-serializing interface. This is life augmentation, smooth integration with the machine world, made to enable and amplify all that one can do.
The system can be asked questions, told to remember things, made to serve information. Complex sequences of physical events can be arranged to occur without human interaction, or in response to human interaction. It makes coffee, and will deliver it. It will collect trash. It shows you the status of the stock market, or of the weather, or of a custom dataset. It can cleanly stop a machine in an emergency. It unlocks a chemical cabinet for an adult, but not for a child. It keeps the human safe, preserves data, and preserves itself to keep maintenance minimal and unobtrusive. It does not become obsolete in less than a year. It will do whatever it is enabled to do.
Almost every component in the system is optional, which makes it highly tolerant to failure. The presence or absence of devices, each with a small number of capabilities, determines the capabilities of the system as a whole.
I call my reactive machine units "Reactrons". These devices have a fairly simple interface that amounts to listing what small set of abilities they have, and control points to execute those abilities. These devices are classified into a handful of groups:
  • Integrons: human interaction nodes
  • Recognizers: human detection and identification nodes
  • Collectors: data acquisition and transmission nodes
  • Transporters: movement of material or data
  • Processors: conversion of material or data
  • Energizers: control of power
This project introduces Integrons and Recognizers as separate, discrete machines. The others are basically all familiar hardware, with a small control board added to provide them the ability to interface with the system.
What this system does:
The main idea is to reduce the complexity and increase the number of machine nodes that are constantly on and around us. Here is a system diagram of the network.  Note that it contains exemplars, and a multiplicity of units exist beyond this scope. The only unique and non-optional thing is YOU, and your time and experience, and that is the whole point.
They detect our position and do things asynchronously so that our needs are anticipated, for a high percentage of the time. Verbal commands and line-of-sight status indicators give a way to interact with the "culture" of nodes, but passive interaction is preferred.  In order of priority:
  • 1) Stuff happens based on rules you set up, so they are ready for you when you need it, sensors detecting your presence and waiting for certain conditions to occur.
  • 2) Status of whatever dataset you like can be seen passively, from a distance, via lights. (...and sound if the system needs to alert you of something you defined.)
  • 3) You can interact verbally from a distance with the Integrons (which then query the full network for the actual answer or status).
  • 4) You can interact up close with the Integrons via screen and by gesture.
It is my hope that most of the interaction is #1 and #2, thereby allowing you to move through your life without interacting actively with the machines, most of the time, analogous to the way the doors just open for Maxwell Smart (https://www.youtube.com/watch?v=sWEvp217Tzw) without him breaking stride, only with more complex results than opening doors.
Here is a system diagram of the Integron unit itself, showing the internal components and how they are expected to interact. The only task of this unit is human integration with the network of nodes, as described above. This post describes what is currently working and what remains as of August 20th 2014.
The simplicity of each node is a huge factor, reducing MTBF for every node, and keeping costs low. Simple machines just work better and last longer. And you can have multiples so that when one breaks another steps in. This allows you to remove maintenance tasks from the critical path of your human activity. Save them up for the chore weekend, or delegate them. The simpler a machine is, the higher the chances are that one can build a machine to do the maintenance.   At critical mass, we have...
View all 19 components
  • Integron as Reactron subcomplex
    Kenji Larsen09/01/2014 at 20:39 0 comments
    Whenever I have a small number of Reactrons that are meant to work together as essentially a single unit, I call the arrangement a subcomplex.  It is a complex, in that it consists of more than one internal Reactron.  But it is "sub" in the sense that these internal units exist below a unified Reactron interface for the complex, so from the outside, it may appear as a single unit.
    As an example, if you consider the Reactron coffemakerwater pump, and coffee-contextualized simple button, those are actually three separate Reactrons.  But, because these Reactrons are a special case scenario, where the button has a one-to-one relationship with the water pump, and the pump has a one-to-one relationship with the coffeemaker reservoir, they could have been structured as a single, three-unit subcomplex, with a single network interface, instead of three.  I didn't do it this way because these units were all conceived and added at completely different points in time.  Additionally, I like keeping the button and pump abstracted, because if I ever need a general purpose button elsewhere, or a pump, these designs can be replicated easily without de-coupling a coffeemaker.  That is one of the basic tenets of Reactron Overdrive - keep units simple and abstracted, and create desired complexity with increased numbers.
    In developing the speech-interacting Integron, I have done a lot of testing and analysis, and suspect that the base unit is perhaps too complex.  It may be truer to the principles to abstract the speech processing from the human interaction, where the Linux module is a sub-Reactron module in its own right, and the sight, gesture, and audio components comprise a separate sub-Reactron.
    I had been working on an "Integron relay" where a subset of the human interaction components were present, but offloaded the heavy processing to a separate unit.  My thought was to create a device that could act as a (door) threshold device, like a doorbell intercom, but fully integrated with the whole network.  If a doorbell, this would be externally mounted, and therefore subject to weather, damage, potential theft, etc.  So it would be beneficial to have it be cheap and replaceable, with nothing critical in it at all.  It would just be a dumb terminal, effectively.
    After a lot of development on the Integron unit, I am thinking this should actually become the standard model.  All Integrons should be a sub-complex, with an Integron relay of whatever form (doorbell, automobiledesktop, wall-mounted, ceiling mounted, wrist-mounted) presented to the human, and all the data processing for speech and most Reactron network functions located on a separate unit. The two sub-units could be physically located together, but need not be.  This will allow the use of much higher performance computers to be utilized for speech processing, and will also create better machine utilization efficiency, since we generally do not need as many speech engines as we do interface points. The separation will allow a few-to-many relationship of engines to human interfaces.
    It also allows a completely different handling of the audio, escaping ALSA and allowing Linux to just handle received waveform data without trying to play it or capture it.  The real question is, will the transport of data to and from the relay units be faster than the capture, processing, and playout all on a local Linux SBC?  I don't know yet, but I am going to test it.
    In the case of the Automobile Integron, I think the hardware will be pretty much the same, but wired and coded differently.  I will still use a BBB for the speech processor, but now the microcontroller will handle the audio capture and playout instead of ALSA. That subcomplex will be entirely local to the car, as GPRS would not be efficient enough data transport, performance-wise, and further, loss of signal would end up disabling the interface.  Also, BBB consumes much less power than a more powerful laptop, which is important as the unit needs...
  • First cut of desktop morphology Integron
    Kenji Larsen08/20/2014 at 04:02 0 comments
    A lot of the Integron unit is working in component parts.  It remains for me to coordinate the various internal subsystems.  Here is an image of the first cut of the desktop morphology.
    In this image the screen is present but not active, and the little ripple in its surface is just the protective plastic which I have not yet removed.  A NeoPixel is activated blue, under an internal diffuser, in front of a sound baffle and support structure joining base disk to top disk.  The fabric sleeve is an acoustically transparent speaker grille fabric.  There is some left-right asymmetry due to uneven tension, due to me assembling and disassembling this prototype a number of times.
    Still working on the mechanical fit and angle of the PIR sensors in the support baffle structure, and I have yet to test the transparency of the acoustic fabric to the ultrasonic sensor.  The infrared passed just fine, so worst case if the ultrasonic does not work I will put a central PIR in a tube to narrow the angle, and use that to indicate presence of someone standing right in front of the unit.  But I'd rather use ultrasonic ranging since then I get an actual distance.
    The unit looks great in a darker setting.
    It also is effective at giving a colored light signal from a distance in normal light, though the camera does not report well what the human eye sees, which is much more even than this image shows.
    The unit in this image does not contain the Beaglebone Black and audio components, I have that assembled on a breadboard separately for testing, but expect to be assembling it all together shortly.  (It does fit - using a proto cape on the BBB.)
    The speech synthesis and speech recognition are working.  The USB sound card is working well, but I am still working on the right microphone and audio amplifier on the output.  Currently I have a capsule electret mic sourced from Adafruit, and it works quite well close up. But I have ordered higher sensitivity ones, because I want to be able to speak to it from a distance, and it's just not there yet.  I have also ordered some adjustable pre-amplified mics, which may be OK if I attenuate the signal all the way down so that the peak-to-peak does not overdrive (!) the mic input. The sound card is apparently able to withstand abuse - I did try a sustained, full 2 volts peak-to-peak signal to see if it would fry (the sound cards are only a few dollars each, that test was worth it to find out the capability.) Terrible sound, of course, super distorted - but it didn't fry the board. We'll see if we have to go there at all. The internal baffle of the Integron unit is designed to be a sound cone. On the output side of things, I am using an Adafruit audio amp, but while it is quite excellent at what it does, it may not be the best choice for this application. I have some less expensive PAM chips on order, and some different ones I have used before in house, I will be experimenting with them soon.  I also changed the speaker to one that was less tinny. The speech output is mono, so I am just using one speaker of a pair.  This unit is really a point source so in some ways it makes sense to combine channels for any potential stereo signal sound files and just use mono.  That makes it more compact.
    The Moteino is driving the NeoPixel without issue, but I will use more than one in the final unit so that the top, middle, and bottom can be illuminated differently to give three different levels of signal.  (That is the idea anyway, we will see if it is practical.) Due to the internal baffling, there may need to be three LEDs per tier to enhance visibility from all sides, so nine total.  I am considering making the screen bezel ring out of translucent white acrylic, and adding another NeoPixel to make that a soft, power-on indicator light (overridable of course, if you want it off).  So ten RGB LEDs.  In...
  • Component changes
    Kenji Larsen08/12/2014 at 03:43 0 comments
    I've been holding off on an official component list until I can stabilize the build a bit more, but I wanted to mention a few things that have occurred since the original plan was hatched, and some of the design decisions involved.
    Without delving too much into the history, I will just say that at one point I was coding a very simple speech recognizer to run on the ATMega328P, and I was able to create some code that was about 85% effective at recognizing a handful of carefully selected keywords that were pretty distinct in their pronunciation. That was the true positive rate. There was also a high-enough-to-be-annoying false positive rate, which would trigger my “initializer” (more on that at a later time). Anyway, I was getting sucked into the details of speech recognition and optimizing for a tiny processor, and this is really not the area where I can add the most value. So, I moved to R.Pi, to try to implement open-source speech recognition using Pocketsphinx, like many other builds. It meant having to use an SBC w/ Linux in addition to the ATMega328P based board, but for this usage I was not so space-constrained so that was OK, even with the added cost and power usage. Also, moving to Linux enabled speech synthesis as well, using festival. Before, I was playing out pre-defined sound files containing sounds and canned speech responses. But I wanted a more general interface, one that could recognize more than a handful of pre-defined keywords, and trigger more than a handful of pre-defined sounds. Ultimately I moved on to BeagleBone Black as the SBC for performance and I/O, but this is just for these Integron units. Other Reactrons that don’t require all this library support are fine on R.Pi, or just stand-alone ATMega328P, or even stand-alone Android devices, based on the specific application.
    A Reactron is defined by its communications protocol and internal data structure, not by its specific hardware complement. I wanted to mention that while my header image shows a panel of ATMega328P boards (based on the Moteino by Low Power Lab), Reactrons are not Arduino clones, though their hardware complement may contain one, several, or none. I chose the image because to me, it evoked “many small computers working together”, which is what the Reactron network is all about. In my other images, you will see a multiplicity of BBBs and R.Pis and other hardware, as the mix of hardware for a generalized Reactron completely depends on its purpose. For instance, some existing Collector units are purely BBB boards with attached sensors, and the software to support the Reactron interface. Some Recognizers are just BBBs running statistical calculations on inputs from Collectors - without any directly attached auxiliary hardware. I haven't had a chance yet to write much about Recognizers, but that is coming soon.
    Moving on to some of the changes, specific to the Integron unit:
    One excellent thing that has changed since I started this project is that the Moteino has been upgraded. [Felix] at Low Power Lab has informed me that all new R4 Moteinos are now shipping with the MCP1703 voltage regulator. This is good news for me, because now I am able to just add “Moteino” to the components list, instead of a board "based on the Moteino", where I would have to do have a separate BOM and so forth. Now, you can just use a stock R4 Moteino (with HopeRF radio and a 4Mbit flash chip) for any of my projects that require an RF enabled ATMega328P-based solution. At the time I started this project, the Moteino was shipping with the MCP1702 voltage regulator, and that meant that using a then-stock Moteino in my 12+V projects (like the Reactron water pump or the newer Automobile Integron) might have resulted in a puff of smoke and little else.
    I would also like to direct your attention to the fact that [Felix] has entered THP with the Moteino Framework, and you should go there and give him a skull. [Felix] is simply amazing and creates an enabling technology for many,...
  • Automobile Integron project posted
    Kenji Larsen07/24/2014 at 15:26 0 comments
    While this main project describes the human integration device (Integron) for living spaces, it does not address what you do when you are not in a general living space such as home or office.  The automobile is another common living space in our private lives that we personally control.
    Automobile Integron
    But it is a mobile one, and one where (at least currently) our faculties are tied up with the activity of driving.  So there are some considerations there for a mobile human integration device.  The main function is still the same, however.  The tie in to leverage the rest of the network of simple nodes to deal with your personal, private data systems is the same.
    Home and office are living spaces, as is the little bubble of the automobile.  The personal mobile bubble of a person is another one, that is not bounded by the confines of a vehicle.  We do see people walking down the street speaking into their bluetooth headset, or engrossed in their smartphone screen - these are just human integration devices at work on the personal mobile space.  There's also Google Glass and smart watches.
    Maybe in the future, the ubiquity of small simple computers in public spaces will allow us to technologically move though our personal living spaces, our mobile bubbles, without being encumbered by too much attention-stealing equipment.  What's going on in our own dataspace is very important to us, and it has caused us to make a compromise with situational awareness. It is clear that we can think while walking.  The problem is time-serializing interfaces, in my opinion.  So it is a public safety issue as well!  The hands-free driving laws validate that idea.
    It would be great if your biometric data could follow you anonymously through nodes, and levels of access to it by the network itself was granted or revoked by you.  Additionally, a similarly moving interface point for you to hit your remote data securely, with similar permissions handles, would allow you to have mobile integration through public spaces.  If an organizing principle allowed companies and people to allocate a small portion of their gear to support this private interfacing, the interaction with computers and physical machines could really be much more pleasant and have less overhead.
    The data may be split across multiple connectivity providers - providing even more security, and also failsafes and redundancy for data transfer.
    Well, for now, the smartphone will continue to be the primary personal bubble interface.  For now, the Reactron network will be concerned with home, office, and car - all spaces in one's personal control.  A smartphone integration app can extend some utility when you are just walking out in the world, the idea being that the phone is in your control as well.  The problem there is that at best, your phone only has a few hints that you are in fact you.  Maybe an app can enforce additional, better security.
  • The Hackaday Prize Stage 1
    Kenji Larsen07/14/2014 at 05:31 0 comments
    Video is up, and added to the project details.  You can tell from the video that there has been a lot of development that I have not documented in the logs... yet.  The video documents a lot of the components as they stand now, but I do expect changes.  I plan to stabilize and refine things a bit more before getting into the full detail, because the last thing I want is to waste anyone's time with information that will be superseded shortly.
    But if there is interest, I will mention the components for the Integron unit here, they are: BeagleBone Black (to run voice recognition and synthesis), some NeoPixel LEDs and a TFT screen (from Adafruit - actually I got the BBBs from Adafruit also), PIR sensors from ebay, and then a handful of other components that may change, and these relate primarily to the sound support. BBB has only one USB port, so I may need to solder in a two-port USB hub (space constraints) to enable more ports. I need one port for a sound card.  Still working with the audio levels of various microphones and amplifiers, the final selection may change.
    My previous version of the Integron was on R.Pi, so I didn't need to add a sound card. The mic sensitivity and selectiveness is something I wanted to improve, so that development is ongoing.  One goal is for these things to be able to really parse speech from a reasonable distance. They do a negotiation when certain sounds are parsed, to see if other nearby units heard the same sound, and use a volume comparison to figure out approximately where in the room the speaker is, and also which Integron unit should handle a response.  This allows you to walk around the room and have continuous integration.  One open item is to create a handoff procedure - right now this targeting decision is at a single point. Once the decision is made, the entire response comes from one unit.  But it would be great, if the response is long, for the sound to follow you around the room, so you aren't chained to one box while you listen.  I deal with this now by just turning the volume up, but ideally I want these machines to speak in a low voice (or one that matches the volume with which you issued a command), so as not to disturb what is going on in the room.  I do not want a loudspeaker broadcast, I just want a little private conversation in my corner of the room, with my machine ambassador.  And later, when I develop better selective targeting, it may be possible for two (or more) users in different parts of the room to have their own different conversations.
    Back to the components.  The ubiquitous HC-SR04 ultrasonic sensor I had lying around, can be sourced on ebay for very little. Speakers, also from ebay, just tiny 1 inch cheapies, but they are pretty loud and adequate for synthesized speech.
    The Arduino clone is based on the open-source Moteino from Low Power Lab.  I had been making these previously, in various forms with either Hope RF radios or WiFly RN-171 for wireless TCP/IP.
    The Moteino doesn't support WiFly directly but you can of course connect one.  However, it is great at supporting RFM12B and RFM69W/HW so if you want an excellent, tiny, 3.3V clone with RF and capacity for flash memory, you should definitely look into these excellent boards.
    I decided to use this pattern and standardizing has really saved me a lot of time, and enabled clean hardware integration.  I will upload my Eagle files to Github, but you can get usable files from Low Power Lab - the only thing that is somewhat different is the silkscreen, and my requirement for certain radios and a flash chip. If you don't need that stuff, or need other stuff for your project, Moteino is the way to go, there are lots of options.  One of the reasons for my own silkscreen is just for me to identify which ones meet my specific standards - I still have a lot of experimental Moteinos in use and they don't all have...
  • Another unit is aggregated (it is futile to resist)
    Kenji Larsen07/14/2014 at 03:39 0 comments
    Similar in spirit to the label maker, I am adding another incidental machine to the network to allow more flexible and complex usage. A simple garden watering valve
    Water valve
    It broke, so instead of replacing it I thought I would use the opportunity to fix and upgrade it, and have it react with my other network nodes such as temperature and humidity sensors, as well as voice control nodes and status indicator nodes.  It's a super-simple machine, and that is what I like about it.  I won't miss the highly-specific one-of-a-kind interface (read: terrible) it came with, and it will be able to do a lot more things than before, by leveraging complexity from the various simple nodes on the netowrk, each with their own simple and singular purposes.
    That's the idea, anyway.
    One by one, as these things come up in life, I will find ways to integrate them.  With home automation, you can basically expect thermostats and door locks, window sensors and control of lights, all these things are possible too.  But I'd much rather have a system that can accept any simple machine, because who knows what you might want or need - or invent. This garden watering timer probably does fall under the scope of home automation, but probably not the label maker.  And I'd rather not have all my devices need to come from a single manufacturer or need to support a specific API directly.  Most simple things don't have an API, like this timer, and that is just fine with me.  To me, having one in a device like this would be just another example of complexity in the wrong spot - don't make the device more complex, driving up the cost and failure rate.  I'll add my stuff.  What I do wish, however, is that manufacturers would design access to control points to attach external devices.  Just expose some solder pads, put them all in one spot, label them.  Or better yet, a slot, like an SD card slot, that could take a small board with microcontroller. That might add one part, but I'd be OK with it if there was a standardization in play.  But I'll take solder pads so no additional complexity or cost in incurred.  And failing that, I will do what I do - hunt for vias and pads and connectors wherever they are on these boards, and tap them.
    I'm not sure which way the future will go on this one.
  • The network grows, one unit at a time
    Kenji Larsen07/04/2014 at 02:39 0 comments
    This week I had a little problem because I grabbed an unlabeled box, and it was not the box I thought it was.
    The problem is sometimes I am too busy to label my boxes, and by that I mean most of the time.  All, maybe?  I think there must be one box that is labeled...
    Solution?  Add a label maker to the Reactron network.  Then I will be able to use voice recognition already handled by the network to simply print out a label on demand, rather than use a serializing interface to slowly and painfully create and print labels the normal way.  I found a cheap label maker for $20, we'll see if I break it or manage to add it to the network, there is some hacking to do.
    Label maker
    This is a really simple hack but that really is the point of Reactron Overdrive. One simple added node to solve a specific problem, but then the node is there and available for other future as-yet-unknown uses.  The point is to augment life's workflows, improve them, and ultimately have less undesired or inefficient machine interface time.  (I'm all for desirable machine interface time, making labels is not that.)
  • Good to the last #endif
    Kenji Larsen06/27/2014 at 03:06 0 comments
    This week has been about coffee.
    I posted three related and inter-related projects:
    Coffee maker
    coffee maker
    automatic water pump to fill the coffee maker
    water pump
    and a switch module
    switch!
    which despite being a separate machine entirely, lives inside the top cover of the coffee maker's water tank, providing a manual water feed button for the pump.
    Links have been added to the side.
    I guess the Quadralope, previously discussed, also counts with respect to coffee.  Yay coffee!
  • Do robots need their own furniture?
    Kenji Larsen06/25/2014 at 16:52 0 comments
    I think the answer is yes.
    The furniture we have in our homes are anti-gravity devices such as tables and chairs, or organizational devices such as cabinets and desks.
    If you have a machine culture in your house, and the robotic units are doing things among themselves, which include moving stuff around, then at minimum they will need transfer stations.  These can be as simple as little, out-of-the-way tables, or something more complex.
    I envision the need for mobile robots to require a recharging station that they can get to and manage on their own.
    There may be the need for organized temporary storage (material buffering).
    It may well be that all of these robotic needs can come together in one piece of furniture - a small footprint, height-adjusting table to facilitate material transfer to different conveyances, with cabinetry below, and a charging port (or several) for robots to charge up along their travels, if necessary.  There may be the case for a precision location beacon, to augment other tracking methods.  If this robot furniture is designed to be stationary, it can be a positional reference for triangulation for any moving objects, including organic ones.
    At what point is this piece of furniture just another robot, albeit a stationary one?  I don't know.  Perhaps it is more properly called an appliance, like an oven or dishwasher, which are machines that don't change location.  But the table-like and organizational aspects seem more like furniture - just not for humans.  And since we would be seeing these items, but not actively interacting with them the way we do with an oven or dishwasher, they should be good looking and innocuous, more like furniture than an appliance.  Perhaps a new designation is appropriate.
    This piece of furniture might be a good place to put the ubiquitous Integron unit, as well.
  • Can robots be furniture? Plus some more stuff...
    Kenji Larsen06/19/2014 at 20:03 0 comments
    A not-fully developed Reactron, the "Quadralope", is basically just a table.  But with movable legs, and a Reactron wireless controller, the idea is that it will bring you your stuff, or take stuff away.
    Quadralope
    It isn't concerned with what the payload is, only where it is going.  The Recognizers have a statistical model of where you are, and a discrete model of where other Reactron units are, so it may dispatch one of these units with a route.  This is just a physical conveyance.  I broke the details of this unit out into a separate project to focus on those details.
    Why legs? Wouldn't wheels suffice? Well, the idea of a Reactron machine culture integrating with the human culture to augment human living means that some things the machines must learn to do, so that we do not have to alter our methods to fit them. We have carpets, hardwood floors, thresholds, furniture, objects on the floor, etc., all for very good, human reasons.  I for one do not want a shiny leveled pathway everywhere in the house, where wheeled service bots can roll (and to which they may be restricted).  A walker can handle these things very well.  The total contact patch of this robot is perhaps five square inches, and it would be programmed to scuttle out of the way, when not specifically delivering something.  "Out of the way" may mean something like "exist in plain sight, but not in a human walkway".  If so, it would help if the robot was in fact furniture - looked good, matched the decor, etc.  (Yes, this prototype needs work to look less robotish, but you get the idea.)
    And bring me coffee!
    Four other Reactron projects were also posted:
    These projects were also broken out to focus on the individual details.
    But the main point here is that these are all Reactron components, integrate with each other, and the number of possible combinations, workflows, and outcomes increase exponentially, the more simple discrete units there are.
    Anything can be a "material processor", like a coffee maker, for instance.  It does not have the human interface built in, nor the means for conveyance to the human, or from the raw material supply (water and ground coffee), nor the means to transport the material (the coffee) to and from the conveyances.  A single machine that did all this would be horribly complex, require lots of tuning and maintenance, and break easily.  But a small critical mass of certain types of machines can result in complex outcomes that allow you to just seamlessly live your life while machines asynchronously manage the things that you allow them to manage.
    We will trust machines much more, to do complex tasks, when they are simpler and more numerous, and coordinated.  They will break less, and have backup when individual units fail.
View all 17 project logs
FrankenPC wrote 08/04/2014 at 21:54 point
This is impressive. It's sort of the holy grail of futurist visions regarding home automation. BEST of luck with this! I'll keep an eye on this.
On a side note, I've been playing around with junk cell phones recently. Buying old Android phones from EBAY to experiment with. Currently I unlock them and play with all kinds of interfaces to various game controllers to play MAME style retro games. Why am I mentioning this? I realized it was sort of pointless to buy boards like RasPi or Beaglebone black when I can buy 2 or 4 processor Android juggernauts for 20$-40$ a pop. AND they come with capacitive high resolution touch screens and incorporate batteries (built in UPS!), GPS, WiFi, etc etc etc. Re-purposing great electronics that will eventually end up in a junk pile seems like a good idea and they work really well. The only hurdle is IO. That's easily taken care of with devices based on Arduino or whatever has a USB, wi-fi or Bluetooth interface.
Kenji Larsen wrote 08/06/2014 at 02:48 point
Thanks for those very kind comments!
The junk cell phones approach is actually great, and I am a huge proponent of repurposing old tech when possible. I chose BBB for the integration units here so I could leverage open source Linux-based locally-hosted voice recognition and synthesis, in a somewhat standardized and abstracted way. For some of my peripheral units I do use older Android devices. I have not connected any of those with additional modules, I just run them on the built-in WiFi. But they are great. They don't stop working just because time has passed. Some are slower, but I don't load them up with stuff they can't handle... that is part of the point here. Keep things running well by making stand-alone components simple and robust.
Partha Srinivasan wrote 01/03/2016 at 10:14 point
The junk phones concept is kick ass - have you been able to repurpose what software you can run on them or are you using Android itself? This will make for a great experiment by itself .. so far people have been able to run only linux which is still plenty useful: http://www.linux-magazine.com/Online/Features/Convert-an-Android-Device-to-Linux
John Boyd wrote 07/24/2014 at 21:13 point
This project is beyond cool! Kudos!
Kenji Larsen wrote 07/25/2014 at 01:11 point
Thanks, I really appreciate the support! I feel I am a bit behind on documentation, but I am trying to get it all shored up soon. I'm doing my best to make the most important pieces off-the-shelf so anyone can build one easily, so some of the components are changing... stay tuned!
Mike Szczys wrote 06/06/2014 at 22:58 point
Cool! Thanks for entering this in The Hackaday Prize. I can't wait to see the specifics on your data transfer for these. Scaling to masses of simple machines is a rabbit hole I want to see to the bottom!
Kenji Larsen wrote 06/07/2014 at 01:50 point
Thanks for having the Prize to enter! You hit it right on the head. Localized node density will have a practical scaling limit. It's the same natural law that governs prices in Manhattan... If you look down that rabbit hole, it's turtles all the way down - I stop counting at seven.
