This entry is a little late - so it's out of order. I received the box from Nick Sayer.
Participating in the last traveling hackerbox was a lot of fun - so much so that I wanted to do another. I was definitely hooked! I wasn’t the only one thinking of continuing either...soon after that one ended (or rather stopped), the last person I sent the previous box too was also hooked. Thus the sprout of a new traveling hackerbox that includes California, Oregon, and Washington - the Traveling COW. Kudos goes out to @Jeremy g. for initiating this box and seeding it with all kinds of goodies. (Also, for coming up with the awesome name.) So glad I was able to be apart of this one too. Here is the start of it...
My contributions…
I was low on stock so I wasn’t able to add some of my USB Tester stuff except for the VA Tester but I did add some other goodies that I had plenty to share with. A while back my dad found a guy online that had a bunch of parts he was giving away as he no longer needed to build some sort of kit he had made. My dad thinking of me, handed them over my way. I ended up with a bunch of goodies...actually more than I probably will ever use at all. So here is what I put into the box to share with the fellow hacker…
Here are the few items I took out and hope to put to good use.
OH! And in the end, I couldn't resist the LCD display , it will make for a fun project...
Can't wait to do this again!
MobileWill
