Burn Babylon Burn!
A project log for Stark coil gun
Coil gun
XylitolXylitol 07/16/2016 at 21:250 Comments
Waiting new components from our Chinese friends due to a fail (comutator have burn inside causing him to be stuck in closed mode and damaged really bad the board.
On second transistor plastic near the screw also melted away due to big current.
Waiting for new components and working on a board fix, probably stuck for a month time to produce also a new batch of board...
Edit: DHL was faster than excepted, received everything and the new switch do an awesome *click* sound.
