First Welding Tests
A project log for A Microwave Oven Transformer Spot Welder
I need a reliable and maintainable spot welder to solder the 18650 batteries of my Powerbucket. This is my version of this basic tool.
michel-kuenemannMichel Kuenemann 07/02/2016 at 21:450 Comments
I made the first "serious" welding test on 3 18650 cells tonight.
The blue part is a piece of heavy gauge copper bar in a thermo sleeve. It serves as a weight to control the welding pressure. Each arm can move independently (to some extent...).
Close up on the welding electrodes
The electrodes are made of machined copper bar. The electrodes are perfectly perpendicular to the surface to be welded. The gap between the electrode is 1.6 mm.
