nrf mesh to mqtt with tracing main steps
A project log for nRF5 Custom Mesh Network
A simpler, more efficient alternative to Z-x, BL-x, Thread, standard RF protocols
wassimWassim 10/04/2019 at 20:040 Comments
Serial output from the usb dongle
Dongle Firmware
https://github.com/nRFMesh/nRF52_Mesh/tree/master/applications/08_usb_dongle
cu can be used to check the output. Hint, stop serial with "~."
cu -l /dev/ttyACM0 -s 460800
Then start a python service to translate the serial to mqtt
Python scripthttps://github.com/HomeSmartMesh/raspi/blob/master/py/nrf_mesh/nrf_mesh.py
python3 py/nrf_mesh/nrf_mesh.py
mosquitto_sub -t 'nrf/#' -v | ts
The "| ts"  is a pipe that adds timestamp
subscribing to the mqtt topic would then show an output format inspired from zigbee2mqtt that allows to mix the custom nrf devices into the rest of the automation chain
used sensors
nRF52 DIY Sensor Taghttps://github.com/nRFMesh/nRF52_Mesh/tree/master/applications/01_sensortag
nRF51 sesnor taghttps://github.com/HomeSmartMesh/IoT_Frameworks/tree/master/nRF51_Sensors/sensors_project
more details about the RF and serial protocol in https://www.homesmartmesh.com/mesh/
