#include <avr/pgmspace.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <Streaming.h>
#include <EEPROM.h>
#include "RTClib.h"
#include <Time.h>
#include <TimeLib.h>
const uint8_t days_in_month [12] PROGMEM = { 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 };
const int chipSelect = 10;
const char string_0[] PROGMEM = "1=0-Falling 1-Rising 2-Both";
const char string_1[] PROGMEM = "2=Scan Intervall";
const char string_2[] PROGMEM = "3=0-Date+time,1-Timestamp,2-Timestamp+Millis,3-Systemmillis,4-Systemmillis+TimeDiff";
const char string_3[] PROGMEM = "4=Output 0-Serial 1-SD 2-Both";
const char string_4[] PROGMEM = "5=Minimal Signal Duration in Ms";
const char string_5[] PROGMEM = "6=Debounce in Ms";
const char string_6[] PROGMEM = "7=Activate Channel 1=On 0=Off";
const char string_7[] PROGMEM = "8=change Channel (1-4)";
const char string_8[] PROGMEM = "9=Save!";
const char string_9[] PROGMEM = "10=Set RTC unixtime UTC!";
const char* const string_table[] PROGMEM = {string_0, string_1, string_2, string_3, string_4, string_5, string_6, string_7, string_8, string_9};
//Beispielconfig
int configs[40] = {1, 5, 2, 0, 50, 10, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
//RTC&Zeit
RTC_DS3231 RTC;
String filename = "";
void setup() {
loadconfigs();
Serial.begin(115200);
if (! RTC.begin())
setSyncProvider(syncProvider);
setSyncInterval(1000);
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
filename += String(now() / 60 / 60);
filename += ".csv";
#define SECONDS_FROM_1970_TO_2000 946684800
int pins[4] = {2, 3, 4, 5}; //Pinconfig
char buffer2[100]; //Serial Buffer
String inputString = ""; //Serial Buffer
boolean stringComplete = false; //Serial Helper
int channel = 1; //Menuhelper
boolean menuactive = false; //Menuhelper
int menuchoice = 0; //Menuhelper
int choicevalue = 0; //Menuhelper
int laststate[4] = {HIGH, HIGH, HIGH, HIGH}; //Statehelper
int state[4] = {HIGH, HIGH, HIGH, HIGH}; //Statehelper
//Testtrash
//int channelorder;
//int chswitch = 1;
//int chswitchbackup;
void loop() {
if (!menuactive)
intervallset();
serialmenu();
//Call between Loops by Serial Input
void serialEvent() {
while (Serial.available()) {
// get the new byte:
char inChar = (char)Serial.read();
if (!menuactive)
inputString += inChar;
if (inChar == '\n') {
stringComplete = true;
} else
if (isDigit(inChar)) {
inputString += (char)inChar;
//MenuPrintout
void menu() {
Serial.print(hour());
Serial.print(":");
Serial.print(minute());
Serial.print(":");
Serial.print(second());
Serial.print("-");
Serial.print(day());
Serial.print(".");
Serial.print(month());
Serial.print(".");
Serial.println(year());
Serial.print("Aktiver Kanal: ");
Serial.println(channel);
for (int i = 0; i <= 9; i++)
{ int test = ((channel - 1) * 10) + i;
int tempwert = configs[((((channel - 1) * 10) + i))];
if (tempwert != -1)
Serial.print(tempwert);
spaces(String(tempwert).length());
strcpy_P(buffer2, (char*)pgm_read_word(&(string_table[i])));
Serial.println(buffer2);
delay( 100 );
//Menucontrol
void serialmenu() {
// Serial.println(menuchoice);
if (stringComplete)
if (!menuactive && inputString == "menu\n")
menuactive = true;
inputString = "";
// menuchoice=0;
menu();
} else if (menuactive && menuchoice == 0)
menuchoice = inputString.toInt();
strcpy_P(buffer2, (PGM_P)pgm_read_word(&(string_table[menuchoice - 1])));
Serial.println("Neuen Wert eingeben!");
inputString = "";
} else if (menuactive && menuchoice == 8)
choicevalue = inputString.toInt();
if (choicevalue < 4) {
channel = choicevalue;
} else
Serial.println("Falsche Eingabe");
inputString = "";
menuchoice = 0;
menu();
} else if...
Kirschner Christoph
