Using a username and password for MQTT
A project log for Garage Door Opener
An ESP8266-based garage door opening device
myles-eftosMyles Eftos 08/07/2016 at 03:590 Comments
Now we have the ESP8266 talking to the MQTT broker, let's have a look at adding some authentication. The simplest form of authentication is a username and password, which Mosquitto supports. It uses a password file that has a list of all the usernames allowed to login as well as hashes of their passwords.
We will need to create a configuration file to tell mosquitto where to find that file - create an etc directory in the mosquitto directory that is in the root of the docker project:
mkdir mosquitto/etc
create a file called passwd and enter the following:
password_file /etc/mosquitto/passwd
allow_anonymous false
We are simply telling Mosquitto to
  1. look for the passwd file in /etc/mosquitto, and
  2. we only want to allow users that have authenticated.
Next, let's use docker to run the mosquitto_passwd command
docker-compose mosquitto run /bin/bash -c "touch /tmp/passwd && mosquitto_passwd -b /tmp/passwd [username] [password] && cat /tmp/passwd && rm /tmp/passwd" > mosquitto/etc/passwd
Let's break that monstrosity down.
Since we haven't set up a docker volume, we can't easily fetch the file from the container, so instead we run bash and pass it a mini script that:
  1. creates a temporary passwd file,
  2. runs mosquitto_passwd (Don't forget to change [username] and [password] to real values),
  3. prints out the file, then
  4. deletes the temporary file.
  5. Finally, (back on the host computer) we pipe the result in to a file mosquotto/etc/passwd.
If that worked, you should see a new file called passwd in the mosquitto/etc folder.
Next, we need to tell docker to copy our new config file and password file into the container when it builds. Open mosquitto/Dockerfile and add the following lines before the EXPOSE command
COPY ./etc/mosquitto.conf /etc/mosquitto/mosquitto.conf
COPY ./etc/passwd /etc/mosquitto/passwd
We should also update the client containers so they can login when we bring docker-compose up
The ENTRYPOINT line should like this for mosquitto-client/Dockerfile.pub
ENTRYPOINT [ "mosquitto_pub", "-h", "mosquitto", "-u", "[username]", "-P", "[password]" ]
and for mosquitto-client/Dockerfile.sub
ENTRYPOINT [ "mosquitto_sub", "-h", "mosquitto", "-u", "[username]", "-P", "[password]" ]
Those are capital Ps - and don't forget to update [username] and [password] to match the values you saved in the passwd file!
Rebuild, and run docker, and you should see the two clients successfully connect, and "Hello World" being printed to the console.
docker-compose build
docker-compose run
Setup Ardiuno
This is a fairly easy modification. Find the line that looks like:
if(!pubSubClient.connect(MQTT_NAME)) {
and change it to
if(!pubSubClient.connect(MQTT_NAME, "[username]", "[password]")) {
Push the code to the ESP8266, run it, and you should see it connect just like it did before! Except this time, it will be using a username and password.You can verify that by using an incorrect username or password - the ESP8266 will never be able to connect.
