spec.uiHere is the code for the actual pyqt GUI. Put it in the same directory as the pyqt_spec_ser.py code. Not in final form, but it works for testing.x-designer - 2.78 kB - 10/03/2017 at 01:18 |
pyqt_spec_ser.pyThis is the Python code for running the Spectrophotometer. It runs on a Linux box, but can be easily modified to run with Windows. Only the command to open the serial port needs to change. This assumes that the LockIn_Spectro2.ino code is running on the Teensy. Not pretty, not final, but works for anyone who wants to play or just see the code.x-python - 4.69 kB - 10/03/2017 at 01:15 |
LockIn_Spectro2.inoThis is the Arduino file for controlling the Teensy. This code is not well commented or especially pretty, but I provide it for those who really want to see how to control the ADA2200 and the other parts of the system.ino - 11.28 kB - 10/03/2017 at 01:11 |
MovingBlade.fcstdSlit Movable razor blade holder in FreeCAD format.x-extension-fcstd - 71.32 kB - 01/06/2017 at 01:32 |
MovingBlade.stlSlit Movable razor blade holder in stl format.sla - 637.09 kB - 01/06/2017 at 01:31 |
Anchor.fcstdSlit Adjusting Bolt Anchor in FreeCADformat.x-extension-fcstd - 17.92 kB - 01/06/2017 at 01:31 |
Anchor.stlSlit Adjusting Bolt Anchor in stl format.sla - 330.16 kB - 01/06/2017 at 01:30 |
FixedBlade.fcstdSlit Fixed razor blade holder in FreeCAD format.x-extension-fcstd - 24.95 kB - 01/06/2017 at 01:30 |
FixedBlade.stlSlit Fixed razor blade holder in stl format.sla - 181.04 kB - 01/06/2017 at 01:30 |
Parts List.pdfParts lists for the Lock-In Amplifier and the LED Supply. Has Digikey part numbers, descriptions, and package.Adobe Portable Document Format - 53.32 kB - 08/11/2016 at 04:21 |
SpectromLEDSupply.schSpectrometer LED constant current supply schematic in KiCAD format.x-kicad-schematic - 22.82 kB - 07/09/2016 at 23:25 |
SpectromLEDSupply.kicad_pcbSpectrometer LED constant current supply pcb in KiCAD format.kicad_pcb - 65.83 kB - 07/09/2016 at 23:25 |
SpecLEDSupplySchematic.pdfSpectrometer LED constant current supply schematic as a pdf for easy viewing.Adobe Portable Document Format - 24.94 kB - 07/09/2016 at 23:25 |
Lock_In.kicad_pcbLock-In Amp pcb in KiCAD format.kicad_pcb - 140.35 kB - 07/09/2016 at 23:22 |
Lock_InSchematic.pdfLock-In Amp schematic ias a convenient pdf.Adobe Portable Document Format - 77.69 kB - 07/09/2016 at 23:22 |
Cuvette1.stlCuvette holder in stl formatsla - 124.59 kB - 07/09/2016 at 23:22 |
Cuvette1.FCStdCuvette holder in FreeCAD format.x-extension-fcstd - 52.67 kB - 07/09/2016 at 23:22 |
Lock_In.schLock-In Amp schematic in KiCAD format.x-kicad-schematic - 39.38 kB - 07/09/2016 at 23:22 |
Cover.stlCuvette holder cover in stl format.sla - 41.49 kB - 07/09/2016 at 23:22 |
Cover.FCStdCuvette holder cover in FreeCAD format.x-extension-fcstd - 13.84 kB - 07/09/2016 at 23:22 |
