A Less Mysterious Display
A project log for Wasteland Jukebox
Retrofuturistic media player and internet radio
Blaine MurphyBlaine Murphy 06/22/2017 at 00:580 Comments
My recent trip to the local thrift shop yielded a new display for the radio. I have decided not to use the MDA monitor and instead use a small RCA color TV/monitor. This is an easy decision since the monitor will accept the Pi's composite output without the need for an adapter.
I have never seen a color tube this small before. There is a speaker grille and a control panel mounted on the side of the unit.
On the back there are inputs for audio and video. I will only be using the video input as the radio cabinet already contains speakers.
The TV is powered by a 12V DC adapter or by a "D" cell battery sled.
The TV is too big to fit in the radio with the casing installed. The casing was a bit dificult to remove, but I managed to get past the outer shell that with a couple pairs of vice grips.
Inside the casing there was the following label:
I should probably find a good way to shield the tube and board once I get it installed in the cabinet. Hopefully something lightweight like aluminum or copper tape will do the trick.
