simple hack rf
make a simple hack rf or fluctuations machine by the ratio of two switches transistors.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
i want to make a hack rf by using the fluctuations of transistor when the light is turn-off the sensor(i have a difference diagram which not use the led,just need to use two transistors to make fluctuation),but i don't sure is that will work as a fluctuation machine or emits the electromagnetic waves?so i need your development and a suggestion,thank.
