First step was finding what I need to keep from old setup
and then what needs to be added new. I ended up keeping the old fuse box,
regulator and ignition system. For the better looks, I wanted to move all of
the components under the seat. For this I needed to make a compartment under
the seat. I used an aluminum plate for this and bent it into the shape needed.
Then I took a multiple conductor cable and run that from between forks to all
the way back of the bike. All of the controls like key, right and left hand controls were connected on one end of the cable and connections tucked into the head light. All of the connections to fuse box and relays were made on other end under the seat.
matthewkleinmann
Quinn
zittware
