Random FM+AM/RDS Tuner + STM32L476
Controlling LC72131 based tuner with BU1924 RDS decoder from STM32L476 Nucleo Board
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I've connected STM32L476 (from Nucleo-L476RG board) to some no-name FM/AM tuner that comes from Marantz amplifier. The tuner was broken down, and after doing the repair I needed to be able to do some testing.
This is what this code does:
- setting new frequency in 100kHz increments after the 'User' button is pressed (communication with LC72131 PLL)
- reading and decoding RDS data stream that comes from BU1924 using STM32 SPI in slave mode, basic info only, station name, radio texts, nothing fancy.
STM PLL Connections:
PC9 - PLLSCK
PC8 - PLLDI
PC6 - PLLDO (currently unused)
PC5 - PLLCE
STM RDS Connections:
PB13 (SPI2_SCK) - RDSCLK
PB15 (SPI2_MOSI) - RDSDAT
STM PC Connections
PA9 (UART1_TXD) - RDS decoded data & debug information (230400 bauds, 8N1)
Simply type in "make all" to build binary image and upload it at the beginning of the flash memory.
