Wood WiFi Touch Screen Pyrotechnics Controller
Laser etched, capacitive touch, drilled out hunk of wood, used to wirelessly control propane pyrotechnics
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Using ESP8266s, more info coming soon. Icons laser etched, as well as a square grid of holes for the 2 color 8x8 LED array. A tiny hole drilled into each icon, just the right size to feed a tiny wire to the surface from behind. All the wires inserted and super-glued in place. Code and circuit will be added soon
