LED light
A project log for Visible Light Communication for the masses
This project will focus on making current research in field of Visible Light Communication (VLC and LiFi) usable and meaningful for use...
jovanJovan 07/07/2016 at 16:320 Comments
First thing you will notice is that 1W or stronger LED light bulbs are out of projects scope.
Main reason is power consumption that exeeds limits of 5W. If we plan to make emiters with 3,4 different color ch. and IR then LEDs with nominal power => 1W is out of scoope.
