Push on, hold off
A power switch using a push button. Push to turn on hold to turn off.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
<a target="_blank" rel="noopener noreferrer" href="https://kitspace.org/boards/github.com/kasbah/push-on-hold-off">https://kitspace.org/boards/github.com/kasbah/push-on-hold-off</a><br><br>A power switch using a push button. It turns on with a single press and only turns off when you hold the button down. This could be used to get functionality similar to most laptops where a single press when on will initiate a &quot;soft&quot; shutdown but you can force a &quot;hard&quot; shutdown by holding it down.
