E3D has a tiny geared extruder. This puts it on a D-Bot
$fs=0.01;
module Wrencher(){
difference(){
union(){
linear_extrude( file = "HaDLogo.dxf", layer = "skull", height = 6, center = false, convexity = 10);
linear_extrude( file = "HaDLogo.dxf", layer = "wrenches_a", height = 4, center = false, convexity = 10);
linear_extrude( file = "HaDLogo.dxf", layer = "wrenches_b", height = 4, center = false, convexity = 10);
translate([0,0,6]){
linear_extrude( file = "HaDLogo.dxf", layer = "face", height = 4, center = true, convexity = 10);
module beltGroove(){
difference(){
union(){
translate([0,-2,3.5]){
cube([7,12.5,2.5]);
translate([0,12.5,0])
rotate([45,0,0])
cube([7,7,2.5]);
for (i = [1:2:12]){
rotate([0,90,0])
translate([0,i,0])
cylinder(d=1,h=7);
translate([-3,5,-0.1])
boltHole();
translate([10,5,-0.1])
boltHole();
translate([0,-4,5])
cube([8,20,10]);
module hexagon(width, rad, height){
hull(){
translate([width/2-rad,0,0])
cylinder(r=rad,h=height);
rotate([0,0,60])
rotate([0,0,120])
rotate([0,0,180])
rotate([0,0,240])
rotate([0,0,300])
module boltHole(){
union(){
hexagon(7,0.25,2.5);
translate([0,0,-2])
cylinder(d=3.3, h=10);
module fanHoles(){
for (i = [20:10:120]){
translate([56,i,0])
boltHole();
module endstop(){
translate([21.5,12.5,-0.1])
boltHole();
translate([40.5,12.5,-0.1])
boltHole();
translate([14.5,1.75,5])
rotate([270,0,0])
cylinder(d=4,h=13);
translate([24,6.25,5])
rotate([90,90,90])
cylinder(d=4,h=15);
module clipHoles(){
translate([5,20,-0.1])
boltHole();
translate([5,30,-0.1])
boltHole();
module inductiveSensor(){
union(){
difference(){
cube([15,35,55]);
translate([-1,16.5,40])
rotate([0,90,0])
cylinder(d=19,h=25);
translate([0,0,10])
cube([10,35,55]);
translate([0,0,10])
rotate([270,0,0])
cylinder(d=20,h=35);
difference(){
translate([-15,0,0])
rotate([0,45,0])
cube([40,5,40]);
translate([15,0,0])
cube([40,40,40]);
translate([-15,0,-40])
cube([80,40,40]);
difference(){
translate([-15,30,0])
rotate([0,45,0])
cube([40,5,40]);
translate([15,0,0])
cube([40,40,40]);
cube([80,40,40]);
module motorMountHoles(){
boltHole();
translate([0,0,7])
cylinder(d=6,h=40);
boltHole();
translate([-15,0,7])
cylinder(d=6,h=40);
translate([-30,0,0])
boltHole();
translate([-30,0,7])
cylinder(d=6,h=40);
translate([-45,0,0])
boltHole();
translate([-45,0,7])
cylinder(d=6,h=40);
translate([0,60,0])
boltHole();
translate([0,60,7])
cylinder(d=6,h=40);
translate([-15,60,0])
boltHole();
translate([-15,60,7])
cylinder(d=6,h=40);
translate([-30,60,0])
boltHole();
translate([-30,60,7])
cylinder(d=6,h=40);
translate([-45,60,0])
boltHole();
translate([-45,60,7])
cylinder(d=6,h=40);
module stepperHoles(){
cylinder(d=23, h=10);
translate([15.5,15.5,0])
cylinder(d=3, h=10);
translate([-15.5,15.5,0])
translate([15.5,-15.5,0])
translate([-15.5,-15.5,0])
module directDriveAdapter(){
difference(){
translate([-50,-5,0])
cube([40,70,25]);
translate([-30,30,15])
stepperHoles();
translate([0,0,-4])
motorMountHoles();
translate([-54,5,0])
cube([60,50,22]);
module dualExtrusionAdapter(){
difference(){
cube([25,70,40]);
translate([0,0,-4])
motorMountHoles();
cube([60,50,25]);
module basePlateFront(){
difference(){
hull(){
translate([0,0,0])
cylinder(d=4, h=5);
translate([62,0,0])
cylinder(d=...
