The Code
A project log for D-Bot Big 'Ol Direct Drive Carriage
E3D has a tiny geared extruder. This puts it on a D-Bot
benchoffBenchoff 07/09/2016 at 17:010 Comments
$fs=0.01;
module Wrencher(){
    difference(){
        union(){
            linear_extrude( file = "HaDLogo.dxf", layer = "skull", height = 6, center = false, convexity = 10);
            linear_extrude( file = "HaDLogo.dxf", layer = "wrenches_a", height = 4, center = false, convexity = 10);
            linear_extrude( file = "HaDLogo.dxf", layer = "wrenches_b", height = 4, center = false, convexity = 10);
        translate([0,0,6]){
            linear_extrude( file = "HaDLogo.dxf", layer = "face", height = 4, center = true, convexity = 10);
module beltGroove(){
 difference(){
     union(){
            translate([0,-2,3.5]){
             cube([7,12.5,2.5]);
             translate([0,12.5,0])
             rotate([45,0,0])
                cube([7,7,2.5]);
             for (i = [1:2:12]){
                rotate([0,90,0])
                translate([0,i,0])
                    cylinder(d=1,h=7);
         translate([-3,5,-0.1])
            boltHole();
         translate([10,5,-0.1])
            boltHole();
      translate([0,-4,5])
         cube([8,20,10]);
module hexagon(width, rad, height){
 hull(){
      translate([width/2-rad,0,0])
        cylinder(r=rad,h=height);
      rotate([0,0,60])
      rotate([0,0,120])
      rotate([0,0,180])
      rotate([0,0,240])
      rotate([0,0,300])
module boltHole(){
    union(){
        hexagon(7,0.25,2.5);
        translate([0,0,-2])
            cylinder(d=3.3, h=10);
module fanHoles(){
  for (i = [20:10:120]){
   translate([56,i,0])
        boltHole();
module endstop(){
    translate([21.5,12.5,-0.1])
        boltHole();
    translate([40.5,12.5,-0.1])
        boltHole();
    translate([14.5,1.75,5])
    rotate([270,0,0])
    cylinder(d=4,h=13);
    translate([24,6.25,5])
    rotate([90,90,90])
    cylinder(d=4,h=15);
module clipHoles(){
  translate([5,20,-0.1])
        boltHole();
  translate([5,30,-0.1])
        boltHole();
module inductiveSensor(){
union(){
        difference(){
            cube([15,35,55]);
            translate([-1,16.5,40])
            rotate([0,90,0])
            cylinder(d=19,h=25);
            translate([0,0,10])
                cube([10,35,55]);
            translate([0,0,10])
            rotate([270,0,0])
            cylinder(d=20,h=35);
    difference(){
        translate([-15,0,0])
        rotate([0,45,0])
        cube([40,5,40]);
        translate([15,0,0])
        cube([40,40,40]);
        translate([-15,0,-40])
        cube([80,40,40]);
        difference(){
        translate([-15,30,0])
        rotate([0,45,0])
        cube([40,5,40]);
        translate([15,0,0])
        cube([40,40,40]);
        cube([80,40,40]);
module motorMountHoles(){
    boltHole();
    translate([0,0,7])
    cylinder(d=6,h=40);
    boltHole();
    translate([-15,0,7])
    cylinder(d=6,h=40);
    translate([-30,0,0])
    boltHole();
    translate([-30,0,7])
    cylinder(d=6,h=40);
    translate([-45,0,0])
    boltHole();
    translate([-45,0,7])
    cylinder(d=6,h=40);
    translate([0,60,0])
    boltHole();
    translate([0,60,7])
    cylinder(d=6,h=40);
    translate([-15,60,0])
    boltHole();
    translate([-15,60,7])
    cylinder(d=6,h=40);
    translate([-30,60,0])
    boltHole();
    translate([-30,60,7])
    cylinder(d=6,h=40);
    translate([-45,60,0])
    boltHole();
    translate([-45,60,7])
    cylinder(d=6,h=40);
module stepperHoles(){
        cylinder(d=23, h=10);
        translate([15.5,15.5,0])
            cylinder(d=3, h=10);
        translate([-15.5,15.5,0])
        translate([15.5,-15.5,0])
        translate([-15.5,-15.5,0])
module directDriveAdapter(){
 difference(){
    translate([-50,-5,0])
    cube([40,70,25]);
    translate([-30,30,15])
     stepperHoles();
    translate([0,0,-4])
    motorMountHoles();
     translate([-54,5,0])
        cube([60,50,22]);
module dualExtrusionAdapter(){
 difference(){
    cube([25,70,40]);
    translate([0,0,-4])
    motorMountHoles();
        cube([60,50,25]);
module basePlateFront(){
difference(){
        hull(){
            translate([0,0,0])
            cylinder(d=4, h=5);
            translate([62,0,0])
            cylinder(d=4, h=5);
            translate([62,140,0])
            cylinder(d=4, h=5);
            translate([0,140,0])
            cylinder(d=4, h=5);
        translate([3,3,-1])
            cylinder(d=5.25, h=7);
        translate([3,137,-1])
        hull(){
            translate([59,137,-1])
            translate([53,137,-1])
        hull(){
            translate([59,3,-1])
            translate([53,3,-1])
        translate([18,0,0.1])
            beltGroove();
        translate([42,140,0.1])
            rotate([0,0,180])
            beltGroove();
        clipHoles();
        translate([0,60,0])
        clipHoles();
        translate([55,55,-0.1])
            motorMountHoles();
    translate([49,10,5])
    inductiveSensor();
module basePlateBack(){
    union(){
    difference(){
            hull(){
                translate([0,0,0])
                cylinder(d=4, h=5);
                translate([62,0,0])
                cylinder(d=4, h=5);
                cylinder(d=4, h=5);
                cylinder(d=4, h=5);
            translate([3,3,-1])
            hull(){
            hull(){
                beltGroove();
                rotate([0,0,180])
                beltGroove();
            translate([0,0,-0.1])
            fanHoles();
            translate([-10,105,0])
                endstop();
    translate([70,20,5])
        scale([0.3,0.3,.3])
            rotate([0,0,90])
                Wrencher();
translate([60,155,0])
directDriveAdapter();
//translate([120,155,0])
//dualExtrusionAdapter();
basePlateFront();
translate([70,0,0])
basePlateBack();
