Updated design (version 2) sent to be manufactured
A project log for Single Chip AVR BASIC Computer
A computer running the BASIC programming language, generating composite video and reading PS/2 keyboard input using a single AVR.
danDan 05/28/2014 at 21:352 Comments
After seeing the HaD post regarding DirtyPCB, I updated the design of the single chip computer (added a reset button, removed the jumper parts, added a capacitor across the AVR supply pins, moved some components closer together etc as shown in the PCB layout below) and sent the files to DirtyPCB. I am currently awaiting the arrival of the PCBs.
Radu Motisan wrote 08/23/2014 at 12:30 point
Hi Dan,
I got all the components for the PCB v0.2 I got for you on Ebay. I would need the circuit diagram and the firmware for this. Thanks!
Dan wrote 08/25/2014 at 19:32 point
Hi Radu,
I sent a copy of the schematic with the PCB and the firmware for the ATmega 1284P microcontroller can be found at the "Code (AVR Sketch)" link on the left hand side of the project page.
Dan
