Panels Acquired and Being Mounted
A project log for Vendotron
A vending machine that allows purchases of items via mobile phone or bitcoin
mike-machadoMike Machado 10/05/2016 at 20:410 Comments
I finally had some time to make it over to the local TAP Plastics and pick up the 1/8" acrylic sheets needed for the sides and rear panels. Since the only holes in these sheets are for the screws to mount into the vertical wood beams, it did not make sense to laser cut them.
Here is a photo showing the progress. You can't really tell but there is an acrylic panel mounted on the closest side in the photo!
