Grazing assy.SLDASMSolidworks assembly, seems temperamental so probably won't work.sldasm - 891.50 kB - 08/22/2016 at 23:02 |
Motor End Cap 3 No Wheel.STLBearing housing roller end cap. Top, driving motor side. Covers gears to enable same roller design for top assembly.Standard Tesselated Geometry - 3.51 MB - 08/22/2016 at 23:02 |
Motor End Cap 3 No Wheel.SLDPRTBearing housing roller end cap. Top, driving motor side. Covers gears to enable same roller design for top assembly.sldprt - 1.34 MB - 08/22/2016 at 23:02 |
Motor end cap 3 With wheel.STLLarge bearing housing roller end cap. Bottom, Driving motor side. Houses motor and covers gears. Also mounts motor and drive wheel.Standard Tesselated Geometry - 4.32 MB - 08/22/2016 at 23:02 |
Motor end cap 3 With Wheel.SLDPRTLarge bearing housing roller end cap. Bottom, Driving motor side. Houses motor and covers gears. Also mounts motor and drive wheel.sldprt - 1.43 MB - 08/22/2016 at 23:02 |
Plain end cap 3+wheel motor.STLBearing housing roller end cap. Bottom, non-geared side. Also mounts motor and drive wheel.Standard Tesselated Geometry - 5.35 MB - 08/22/2016 at 23:01 |
Plain end cap 3 no wheel.STLBearing housing roller end cap. Top, non-geared side.Standard Tesselated Geometry - 3.90 MB - 08/22/2016 at 23:01 |
Plain end cap 3+wheel motor.SLDPRTBearing housing roller end cap. Bottom, non-geared side. Also mounts motor and drive wheel.sldprt - 1.33 MB - 08/22/2016 at 23:01 |
Plain end cap 3 no wheel.SLDPRTBearing housing roller end cap. Top, non-geared side.sldprt - 1.16 MB - 08/22/2016 at 23:01 |
BearingSpacerMunching.SLDPRTSpacer to pack 6mm shaft into 10mm bearing and prevent rubbing. For muching drive.sldprt - 1.08 MB - 08/22/2016 at 23:00 |
BearingSpacerMunching.STLSpacer to pack 6mm shaft into 10mm bearing and prevent rubbing. For muching drive.Standard Tesselated Geometry - 109.85 kB - 08/22/2016 at 23:00 |
BearingSpacerDriveWheel.SLDPRTSpacer to pack 6mm shaft into 8mm bearing and prevent rubbing. For drive wheel.sldprt - 2.12 MB - 08/22/2016 at 22:59 |
BearingSpacerDriveWheel.STLSpacer to pack 6mm shaft into 8mm bearing and prevent rubbing. For drive wheel.Standard Tesselated Geometry - 72.93 kB - 08/22/2016 at 22:59 |
Drive Wheel.SLDPRTWheel with drive hub cut out (and superfluous gear profile just in case)sldprt - 1.16 MB - 08/22/2016 at 22:59 |
Drive Wheel.STLWheel with drive hub cut out (and superfluous gear profile just in case)Standard Tesselated Geometry - 717.17 kB - 08/22/2016 at 22:59 |
5beltRoller.SLDPRTRoller without motor end (just stubs to fit bearings)sldprt - 1.21 MB - 08/22/2016 at 22:59 |
5beltRollerMotor.STLRoller with cut out for motor shaft hubStandard Tesselated Geometry - 977.13 kB - 08/22/2016 at 22:59 |
5beltRollerMotor.SLDPRTRoller with cut out for motor shaft hubsldprt - 1.26 MB - 08/22/2016 at 22:59 |
5beltRoller.STLRoller without motor end (just stubs to fit bearings)Standard Tesselated Geometry - 858.48 kB - 08/22/2016 at 22:59 |
