Catch up
A project log for Photobooth Thermal Printer - Can I get a reciept?
Ideal for your party or hallway! Press the big red shiny button and take a photo! It is then saved in a slideshow and prints a copy for you!
isaxiSax 04/10/2018 at 08:430 Comments
So I started this before Hackaday, but here is a breakdown of whats happened.
1. I found a nice acrylic board with bent edges in a dumpster and places the Big Red Shiny Button and a screen in a nice looking symmetrical way.
I then did the maiden job for my Dremel and milled out a hole for the button and screen.
I stripped the screen from it's original case and installed Raspbian on an SD card.
Then is was mounted on a piece of plywood behind the case.
Then I also mounted the camera above the screen.
