Tron wrecked two expensive end stop sensors for the Z axis. I wonder what else got wrecked during the lift?
One other little problem. The x traverse will collide with Tron's right leg stiffeners when it homes. Fortunately, It's easily fixed by removing the short bed and changing a spacer block.
