Pokemon go plus has arrived
A project log for Pokemon Go Plus DIY
Project to create your own pokemon go plus
sabasSabas 09/05/2019 at 23:123 Comments
Today
the pokemon go plus that I requested has arrived
I have proven that it is working correctly and now I have opened it
Tomorrow I will solder the necessary cables
see you tomorrow
fungi wrote 01/26/2021 at 21:20 point
is this project still on going? it says it is on the github page, but I am unsure as it has not been updated in a little over 4 years, and I would like to continue learning about this project.
Suzhou65 wrote 10/05/2019 at 13:08 point
Hey , I notice that maybe you bought the pirated version PGP just like me.
https://github.takahashi65.info/lib_img/github_pokemon_compare.png
https://github.com/Suzhou65/Arduino-Play-PokemonGoPlus
It's not a big problem, the PGP firmware can be used too, but some pirated version PGP using same BLE device mac-address, in some case like Safari Zone, when there is many people using PGP, pirated version PGP has high possibility disconnect due to channel jamming.
So, maybe needs some modify about BLE device mac-address
TehPirate wrote 09/16/2019 at 15:10 point
When can you post a follow up?
