Jamma Supergun iTX
A jamma supergun inside an PC case for easy arcade home gaming.
Arcade games run over a standard connector called JAMMA which carries voltage, controllers, display and sound signals.
Some additional boards and adapters are required to run a game on a computer monitor via VGA or even in a CRT via RGB video.
This project will try to do such adapter to use arcade games as a video game console, that's commonly called a Supergun, ATX like cases will be used for storing of wiring, adapters and for it be able to use computer PSUs.
It will be able to use NeoGeo, CPS2 and other JAMMA standard games.
Los juegos de arcade usan un standard llamado JAMMA (lol), este conector lleva las señales de video, voltaje, sonido y control.
Algunas placas y adaptadores adicionales son necesarios para correr un juego en un monitor de computadora usando cable VGA o en un monitor CRT con entrada de video RGB.
Este proyecto intentara construir un adaptador para usar juegos de arcade como video juegos caseros, eso se llama cotidinamente una Supergun. Se emplearan gabinetes ATX para poder usar PSUs de computadora.
Se podrán jugar videojuegos de NeoGeo, CPS2 y cualquier cosa que use el formato JAMMA.
Standard Tesselated Geometry - 68.54 kB - 07/15/2016 at 19:51
Download
postscript - 1.53 MB - 07/15/2016 at 19:51
Download
svg+xml - 3.34 kB - 07/15/2016 at 19:51
Download
  • 1 × JST 2.5 XH 12-Pin Female Connector
  • 1 × JST 5p-SVF-V
  • 1 × iTX Case
  • 1 × ATX Power supply
  • 1 × Jamma Connector
View all 11 components
View all 2 project logs
