USE_3D_Printer_RGB_MAX31855.inoUSE_3D_Printer_RGB_MAX31855.inoThis is for the MAX31855, a better chip, using Arduino Nano ino - 7.08 kB - 08/26/2016 at 08:55 |
USE_3D_Printer_Heatbed_RGB.ino// RGB LED Colours// Blue indicates an error with the Thermocouple Temperature Measuring Probe Sensor // Less than or equal to 35°C Green. Cool safe // More than 35°C Less than or equal to 45°C Yellow. Medium Heat. This is red + some green, not total green // More than 45°C Less than or equal to 50°C Red. Solid. Hot Danger do not touch // More than 50°C Less than or equal to 170°C Red. Flashing. Very Hot Danger do not touch // More than 170°C White Quick Flashing Red + Green + Blue LED : TOO HOT!!!! OVER Temperature ERROR!!! ino - 7.50 kB - 08/12/2016 at 17:52 |
