MAX31855K Thermocouple Sensor
A project log for Fitting Heat Bed warning RGB LED
To warn using colours of RGB LED that the that the heatbed is hot.
films4youFilms4You 08/18/2016 at 00:160 Comments
I have a MAX31855K Thermocouple Sensor Module Temperature Detection Development Module on order I believe this will return better results.
This will need a different Library foo the Arduino Nano code
e.g Adafruit_MAX31855
