Cleaninator : Autonomous Cleaning Robot : it can clean even difficult spaces :
Demonstration :
See build and logs for more details !
Extremely Low Cost Autonomous Cleaning Robot, using brush propulsion and rechargeable Ni-Mh battery
Demonstration :
CLEANINATOR_REVA.jpgFirst test version of cleaninator, alkaline battery and no on/off switchJPEG Image - 282.00 kB - 07/17/2016 at 16:14 |
Now changing to a Ni Mh Battery allows a bit more current and makes the cleaninator even faster
In total 2 prototypes were built, 1 by E (14y old), and 1 by B (11y old).
the first one rotates a lot and moves slowly. This may be excellent for thorough cleaning.
the second one moves fast and doesn't rotate.
The difference is in the weight balancing, in positioning the battery holder and motor,
and in the selection of the asymmetric load.
By choosing the position, you can physically 'program' the robot behavior.
Here is a video comparing the behavior of the 2 prototypes :
Glued it all together, it looks good !
Clean up the excessive glue
First tests were done with a motor on the table.
Take a small cleaning brush (different types may work).
Test if it slides well over the floor, if it keeps balance, you have a good brush.
If it tips over, you can cut the brush hairs into a more stable shape.
Solder a small DC motor to an AA battery holder, add a switch in between. Test the circuit on your desk.
If it works, add some assymetric weight to the motor axis, such as these two bolts :
Test the vibration of the motor with the asymetric assembly. If it moves slowly on your table, you did well.
Now glue the motor to the brush, leave some space for the switch and the battery holder.
Elevate your living space with Cleaning Pros Servicing. Our dedicated team provides impeccable service, ensuring a spotless and refreshing environment. Experience the pinnacle of cleanliness with our professional touch.
