Cleaninator : Low Cost Autonomous Cleaning Robot
Extremely Low Cost Autonomous Cleaning Robot, using brush propulsion and rechargeable Ni-Mh battery
Minimal Autonomous Cleaning Robot, cleans the floor powered by electro motor vibrated brush and navigating randomly. It has no brain, so no risk it will take over the world. It is easy and cheap to build, inspired by the toothbrush based bristlebot. My 2 sons B. (11y) and E. (14y) each built one.
Cleaninator : Autonomous Cleaning Robot : it can clean even difficult spaces :
Demonstration :
See build and logs for more details !
First test version of cleaninator, alkaline battery and no on/off switch
JPEG Image - 282.00 kB - 07/17/2016 at 16:14
Preview
Download
  • 1 × Brush
  • 1 × AA battery Holder
  • 1 × DC Motor
  • 1 × On/Off Switch
  • 1 × AA Battery
View all 6 components
  • Swapping to Ni Mh Battery
    serdef07/17/2016 at 16:55 0 comments
    Now changing to a Ni Mh Battery allows a bit more current and makes the cleaninator even faster
  • Creating 2 prototypes
    serdef07/17/2016 at 16:53 0 comments
    In total 2 prototypes were built, 1 by E (14y old), and 1 by B (11y old).
    the first one rotates a lot and moves slowly. This may be excellent for thorough cleaning.
    the second one moves fast and doesn't rotate.
    The difference is in the weight balancing, in positioning the battery holder and motor,
    and in the selection of the asymmetric load.
    By choosing the position, you can physically 'program' the robot behavior.
    Here is a video comparing the behavior of the 2 prototypes :
  • Glueing it all together
    serdef07/17/2016 at 16:40 0 comments
    Glued it all together, it looks good !
    Clean up the excessive glue
  • Testing before build
    serdef07/17/2016 at 16:38 0 comments
    First tests were done with a motor on the table.
View all 4 project logs
  • 1
    Step 1
    Take a small cleaning brush (different types may work).
    Test if it slides well over the floor, if it keeps balance, you have a good brush.
    If it tips over, you can cut the brush hairs into a more stable shape.
  • 2
    Step 2
    Solder a small DC motor to an AA battery holder, add a switch in between. Test the circuit on your desk.
    If it works, add some assymetric weight to the motor axis, such as these two bolts :
    Test the vibration of the motor with the asymetric assembly. If it moves slowly on your table, you did well.
  • 3
    Step 3
    Now glue the motor to the brush, leave some space for the switch and the battery holder.
View all 5 instructions
tariqkhanop890 wrote 02/10/2024 at 06:31 point
Elevate your living space with Cleaning Pros Servicing. Our dedicated team provides impeccable service, ensuring a spotless and refreshing environment. Experience the pinnacle of cleanliness with our professional touch.
Darko Sarkanovic wrote 07/17/2016 at 20:57 point
Absoliuely ingenious.
