Setting up a a quadrature encoder with the tm4c123 qei
The code for this was written in code composer studio, but as far as the encoder goes, it is the same.
The code taken from http://forum.43oh.com/topic/8875-problems-using-qei-with-ek-tm4c123gxl/ is good, and makes testing simple. The post was created because the person was actually using hall effect sensors for feedback, not an encoder.
#include <stdint.h> #include <stdbool.h> #include "inc/hw_gpio.h" #include "inc/hw_ints.h" #include "inc/hw_memmap.h" #include "inc/hw_types.h" #include "driverlib/gpio.h" #define PART_TM4C123GH6PM #include "driverlib/pin_map.h" #include "driverlib/qei.h" #include "driverlib/sysctl.h" void config_QEI() { SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD); //Unlock GPIOD7 HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY; HWREG(GPIO_PORTD_BASE + GPIO_O_CR) |= 0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_AFSEL) &= ~0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_DEN) |= 0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = 0; // Enable QEI Peripherals SysCtlPeripheralEnable(SYSCTL_PERIPH_QEI0); //Set Pins to be PHA0 and PHB0 GPIOPinConfigure(GPIO_PD6_PHA0); //GPIOPinConfigure(0x00031806); //0x00031806 =>GPIO_PD6_PHA0 GPIOPinConfigure(GPIO_PD7_PHB0); //GPIOPinConfigure(0x00031C06); // 0x00031C06 => GPIO_PD7_PHB0 //Set GPIO pins for QEI GPIOPinTypeQEI(GPIO_PORTD_BASE, (GPIO_PIN_6 | GPIO_PIN_7)); //HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_M; // Configure quadrature encoder, use an arbitrary top limit of 2000 and enable QEI QEIConfigure(QEI0_BASE,(QEI_CONFIG_CAPTURE_A | QEI_CONFIG_NO_RESET | QEI_CONFIG_QUADRATURE | QEI_CONFIG_NO_SWAP), 2000); QEIEnable(QEI0_BASE); //Set position to a middle value QEIPositionSet(QEI0_BASE, 1000); //Configure and enable velocity QEIVelocityConfigure(QEI0_BASE, QEI_VELDIV_1, SysCtlClockGet()); // Divide by clock speed to get counts/sec QEIVelocityEnable(QEI0_BASE); } void setup() { config_QEI(); Serial.begin(9600); Serial.println("Start:"); Serial.println("--------"); } void loop() { uint32_t velocity, position; int32_t rotatingdirection; position = QEIPositionGet(QEI0_BASE); velocity = QEIVelocityGet(QEI0_BASE); rotatingdirection = QEIDirectionGet(QEI0_BASE); Serial.println(position); Serial.println(velocity); Serial.println(rotatingdirection); Serial.println("--------"); delay(1000); }
Output:
View all 3 project logs
Paul Gould
agp.cooper
Open Technology
schwarzrmsu
Yes, delete it Cancel
You are about to report the project "TI ek-tm4c123gxl QEI & AMT312D", please tell us the reason.
