Round Robin approach.
A project log for Inexpensive Lightweight Speech Recognition
A mostly hardware based solution suitable for micro controllers and other small systems.
thundersqueakThunderSqueak 08/22/2016 at 07:390 Comments
In initial tests using a spectrum analyzer I was able to differentiate between several different sound occurrences based upon the spectrum of each of those components. I was considering the way that the chip I am using captures the audio. It occurs in such a way that it uses a round robin approach in order to scan the spectrum, each a few ns apart. This might be useful when trying to capture words directly as well as other sounds as in a word, there is definitely a progression of different tones that go together to create a recognizable phonetic.
